01-13-2020 07:56 - last edited on 09-24-2020 19:06 by
my fone has decided it can't find my fitbit device, any ideas folks
01-13-2020 12:59
01-13-2020 12:59
I've also had this problem before. Here is how to resolve it:
1. Plug your charger into a wall socket.
2. Place your Fitbit onto the charger and make sure the little metal prongs line up.
3. Press on the left "button" for 8 seconds. You should see the display disappear and a loading bar light up. Shortly after that you will see a smiling face.
4. Try to sync again.
5. Expect to have to repeat this occasionally.
Good luck!
01-13-2020 12:59
01-13-2020 12:59
Good luck!
01-18-2020 13:36
01-18-2020 13:36
sorry, its late but it worked very well, thank you once more x
