@pammydue20 you can choose between 12 and 24 hour clocks in your profile settings on the web at https://www.fitbit.com/settings/profile
Once changed and saved, the next time you sync your fitbit will be updated.
Best AnswerHahahaha! I knew something wouldn't work. When I go to settings there is no choice for 'time' only for alarm!!
do you not see a "clock display time" setting on that link? I don't see any alarm setting there so I'm not sure where you are
