02-04-2020 23:59
02-04-2020 23:59
Hi, I deleted the weight tracker from my Fitbit app thinking it will stop showing my weight on my watch. Now it still shows up on my watch but not in the app and I can’t edit it anymore. How do I add it back in the app? I have an inspire HR Fitbit connected to an iPhone
thank you!
Best Answer02-05-2020 04:15
02-05-2020 04:15
@Cristina17 I'm sorry, but the suggestion offered by @WendyB is for an older version of the app. If you want to add your tile back to your phone dashboard, do the following:
To rearrange your tiles, do the following:
Laurie | Maryland
Best Answer02-05-2020 00:22 - edited 02-05-2020 00:29
Welcome to the forums!
In the app scroll down until you see edit. Once there put a check mark on the tile to make it show. Scroll down and again and top done
As for the watch please go vote for it here. Hopefully it will get changed
Hope to see you around!
Wendy | CA | Moto G6 Android
02-05-2020 04:15
Laurie | Maryland
Best Answer02-05-2020 04:28
02-05-2020 04:28
It still doesn’t appear
Best Answer02-05-2020 04:37
02-05-2020 04:37
Thank you! It worked now 🙂
02-06-2020 16:22
02-06-2020 16:22
If you don't want weight to show on your watch, do the following:
1) In the app, go to Weight, select Add or Edit Goal. On the next menu make sure you select Lose. Enter a weight that is 2 lbs less than your current weight.
2) Back on the Weight page, select Log Weight. Enter a weight that is 4 lbs greater than your current weight.
3) Back on the Weight page, select Log Weight. Enter a weight that is 2 lbs greater than your current weight.
4) Back on the Weight page, select Log Weight. Enter your current weight.
Your watch will now show -2 lbs instead of your weight.
