I switched from Garmin to Fitbit yesterday and I have some questions:
1. How do you change the order of stats (heart rate, steps) you see when swiping up?
2. How do I remove my weight from my watch? I don't want to see it on my watch.
Best AnswerThis worked for me on my Charge 3.
If you don't want weight to show on your watch, do the following:
1) In the app, go to Weight, select Add or Edit Goal. On the next menu make sure you select Lose. Enter a weight that is 2 lbs less than your current weight.
2) Back on the Weight page, select Log Weight. Enter a weight that is 4 lbs greater than your current weight.
3) Back on the Weight page, select Log Weight. Enter a weight that is 2 lbs greater than your current weight.
4) Back on the Weight page, select Log Weight. Enter your current weight.
Your watch will now show -2 lbs instead of your weight.
