09-29-2019 19:18
09-29-2019 19:18
On 2 occasions I almost lost my Inspire when the band detached from the device. Now it will not hold at all so I cannot wear it. It is not the band or pin but the actual housing to the device. One corner appears to have no hole for the pin to pop into. The device was purchased in June. I need a replacement device.
09-29-2019 20:50
09-29-2019 20:50
Hi @jquirk Get with customer support. Their phone number is (877)623-4997 between the hours of 4am-8pm PST Mon-Fri, and 6am-5pm PST on weekends, if you're in the USA. If you're not in the USA or if you prefer an online chat or email, then click for contact options
09-29-2019 20:50
09-29-2019 20:50
09-30-2019 09:50
09-30-2019 09:50
Contacted support and a new device will be received in 5-7 business days. thank you!!!
09-30-2019 09:57
09-30-2019 09:57
Wonderful news @jquirk
Best Answer01-15-2020 22:38
01-15-2020 22:38
Did they actually follow through and replace your device? I’ve been fighting with them for over a week and they are saying they aren’t going to make it right. I’m so frustrated with them!
Best Answer01-16-2020 04:27
01-16-2020 04:27
01-16-2020 04:29
01-16-2020 04:29
Yes they did. I received it as promised. The design is really flawed and I see the same thing happening with this device. The Alta had metal clips holding the device. Much more secure.
Best Answer01-16-2020 06:02
01-16-2020 06:02
Best Answer01-16-2020 06:08
01-16-2020 06:08
Best Answer01-16-2020 06:29
01-16-2020 06:29
Yes, another inspire. I like to change bands so trying to do that a lot less. Maybe it will last longer. The Alta only lasted 2 years. Hopefully I can get 2 years out of this one
Best Answer01-16-2020 06:54
01-16-2020 06:54
With the design being so bad, how are you able to switch out the bands? I’m having such a difficult time with the tiny pins and the tight place you have to get in to just to swap out the bands. I bought the inspire hrs lilac and IV not been able to wear it for the past month because of the mechanism they have for this model. I bought a ton of bands but now it’s just sitting in a pile 😞 I’m so unhappy with, not only the design but also with the way I’m being treated by customer service!
01-16-2020 09:27
01-16-2020 09:27
Best Answer01-16-2020 09:39
01-16-2020 09:39
