What's the average time for battery to hold charge? My Inspire HR is about two weeks and the battery charges last only two days.
09:47
07:46
09-10-2019
09:47
07:46
@Pyramid7 It's great to see that you've visited the Fitbit Community!
Let me help you with your Inspire HR battery life. The life is expected to be up to 5 days but it will depend on how you use it. Still you can try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves. You can also find additional suggestions here.
Let me know how it goes.
Best AnswerI followed the suggestion on restarting my Inspire HR (did it two different days), but it still only holds its charge for 21/2 days. I have only had this Fitbit three weeks.
And another thing, the exercise activity comes on randomly even when I'm just sitting.
Not very happy with the Inspire HR!!!!!
Best AnswerMaybe you could try to disable the SmartTrack feature (auto tracking) and see if you have longer battery duration ?
HOW DO I AUTOMATICALLY TRACK ACTIVITY WITH MY FITBIT DEVICE?
