Hi @Knacj To change your email address you need to do it from the website dashboard, rather than the app. On this forum page, go right to the top right corner and select Dashboard. On the page that comes up select the little gear wheel icon in the top right and then select Settings from the drop down menu. Scroll down a bit and you will find 'Change Email Address'
Please come back if you have problems.
Helen | Western Australia
If your having problems finding the correct page @Knacj try https://www.fitbit.com/settings
