04-11-2019 13:48
04-11-2019 13:48
I purchased an Inspire HR about a week ago and now I am getting a "connected gps is running" message on my phone via the app which is draining my battery.
Any ideas how to fix this?
Best Answer04-11-2019 14:41
04-11-2019 14:41
It sounds like you have accidentally started an exercise in your Inspire HR. Give the button a short press. If you see a sideways triangle, give it another press to finish the activity!
If your Inspire HR is not showing any current activity running and your app is telling you that there is a connected GPS activity running, I would suggest logging out of the app to terminate the activity, and then logging back in again. When you log back in again be sure to select "log in" and NOT "join Fitbit" and be sure to use the same email and password you used to set up your account.
I hope this helps. Welcome to the forums!
Best Answer04-11-2019 14:49
04-11-2019 14:49
Thank you Julia, been stressing all day trying to fix it!
Looks like I may have started an exercise by accident and fingers crossed that has fixed it!
Thank you so much!!!😊
