It depends on which model it is.
See Can I use more than one Fitbit device with the same account?
Specifically note:
Note that you can't connect multiple devices that use the Fitbit App Gallery to one account. For Fitbit Charge 3, Fitbit Charge 4, Fitbit Ionic, Fitbit Inspire series, and Fitbit Versa series, only connect one of these devices to your account at a time.
If your 2nd Fitbit is an older model not mentioned above, then you should be able to do so.
@Tiannemyers wrote:
I have 2 inspire hr. So I can’t do it?
Tia Myers
Unfortunately, correct, you cannot.
