Hi @Camden-Kash No you shouldn't have to sync daily. Once a week should be enough to get all your stats. When you sync seveeal days stats, if you tap the < on the left of 'Today' at the top, what comes up?
If you go into the exercise tile (running man), does that show you what activities you have done on previous days?
Try restarting your Inspire several times and see if that helps. Also, what phone are you using?
Helen | Western Australia
Best AnswerI did as you've said and now the missed data appears. Thank you.
I am using a 1+ android phone.
I think there may be a delay in showing the data for previous day's.
Best AnswerThere is only one One plus phone on the Supported Devices List - the 6. I am assuming yours is not this one and the delay is a compatability problem, but I dont really know. I'm glad the data isnt lost anyway.
