Hi all, I go for a daily cycle. Usually about 6-9k. The last two days I have not had more than .68k show up on my app when sync'd.
Today on my ride I checked the inspire HR on my wrist every few minutes to make sure it was working and I ended my workout as usual.
Why is the data not transfering from the tracker to the app correctly??
Best Answer@Alishamly Are you using the “bike” exercise function on your Inspire? Or are you relying on it to auto recognize the workout?
Best AnswerHi @Heather-S , using the "bike" exercise tab.
As per below seems to follow my beginning then drop off.
Best Answer@Alishamly It almost seems like your phone is losing connection or searching for a signal. Have you tried anymore bike rides? Have any correctly transferred the data?
