05-25-2020 02:50
05-25-2020 02:50
My fit bit inspire HR won't navigate. Just stuck on clock. Can't see my steps or anything else. Tried pressing the side button . Moving wrist still stuck on clock.
Best Answer05-25-2020 06:34
05-25-2020 06:34
Here are two things to try:
1. Restart the unit. put on charger and while on charger press the left button for 15-20 seconds until you see the smiley face. This should restart/reboot the software.
2. if the above does not work, the one thing that worked for me was to go to the phone app and change the clockface, then switch back. That cleared up the problem for me.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
05-25-2020 06:34
05-25-2020 06:34
05-25-2020 07:41
05-25-2020 07:41
Thank you! That worked putting it on the charger and hold the button for 15 to 20 sec. Thank you again.
Best Answer05-14-2021 11:33
05-14-2021 11:33
You legend number 2 worked for me immediately wish I had a chance to see it before my workout! Thanks so much!
