11-18-2019
02:25
04:25
AlvaroFitbit
11-18-2019
02:25
04:25
AlvaroFitbit
Can't get my Fitbit to turn on or connect any advice please
11-19-2019
04:43
10:53
11-19-2019
04:43
10:53
@Aarcolrian Welcome to the Fitbit Community! It's great to have you here!
Let me help you with your unresponsive Inspire. Not sure if this is a charging or display issue so I suggest you try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves.
Let me know how it goes.
