Hi not a great fan of band wearables. Have been really happy with my Fitbit One apparently now discontinued. I'm not the only one who prefers Fitbit One. I have been told there is a clip for the Fitbit Inspire but only fits the the standard model. I like the spec of the Inspire HR but sadly the clip does not fit.
Do you think this is all a bit short sighted of Fitbit to discontinue the Fitbit One and also not make the clip universal?
I don't think it's possible to make a universal clip that works well. Just between the Inspire and Inspire HR, there are differences in size that makes using the Fitbit clip on anything but the Inspire a problem.
I think part of the issue is for HR, you need the tracker up against the wrist. And for clip on, it's worn somewhere else, where HR signal wouldn't work.
