My Fitbit is recording the wrong sleep times. It says I slept between 12:21 and 2:05 PM, and I did not. It also said I slept until 11:08 AM, this morning, and I actually woke up around 8:30 AM. My Fitbit does this often.
Anyone know what can be done about this?
Best AnswerHi, Can't you just go into your dashboard and there is a Log section highlighted in lime green. You can change the times, that you wrote down and you can add them, it should look like this that I copied and pasted below. Which they had me remove it, sorry! I have a Fitbit ONE and you can do this or you might have to re-sync it? I hope this helps you Dancing Coyote.
Thursday, Dec 2, 2021
