Fitbit app not showing sleep patterns, gets stuck
Not working! It freezes the entire app!
2 REPLIES 2
Are you using the iOS app? If so, have a look at the following thread where Fitbit are posting updates on a known problem that might be the cause of your issue:
https://community.fitbit.com/t5/iOS-App/Fitbit-app-crashes-with-new-app-update-3-39-when-using-an-iP...
@KayteeBg08 It's great to have you here!
Let me help you with this. As @SteveH mentioned this could an issue affecting the iOS  app. Still I suggest you log out from the app, restart your phone and log back in. After this check if you can access the sleep area.
Hope this helps.
Alvaro | Community Moderator
