07-25-2020 06:43
07-25-2020 06:43
Device not tracking steps it measures everything else. I have re synced. Recorded step length. Restarted device and deleted and downloaded app. I have also re added the device. Still no luck
07-25-2020 11:47
07-25-2020 11:47
Hi, @Dora711 , are you seeing steps on your Fitbit itself, but not in your app, or are you not seeing steps on either?
What happens if you swipe upwards on your Inspire? Do you see information about yur daily activity? Can you tell us what you see?
07-27-2020 06:36
07-27-2020 06:36
Steps are not recording on device or phone. When swipe up can see the time and calories the rest is ‘0’
Best Answer07-27-2020 18:09
07-27-2020 18:09
same problem here, wear it all day but steps don’t calculate
Best Answer07-27-2020 23:43
07-27-2020 23:43
@heatheryyyy @and @Dora711 @counting steps is the most basic function of a Fitbit. Please try the restart procedure:
If that doesn’t fix your issue I would recommend getting in touch with Fitbit Customer Support on Contact.fitbit.com
