02-16-2021
13:41
03:16
WilsonFitbit
02-16-2021
13:41
03:16
WilsonFitbit
How does the Inspire 2 track a 23 yard pool? I don't see a setting to adjust the pool length.
I can only select yards or meters.
@bobmunder thank you for reading the information!
Looks like you should be able to find the Pool settings option by doing the following:
> Swim.
Can you confirm if you're able to find this setting on your Inspire 2?
I look forward to your response.
Hello @bobmunder, welcome to the community forums!
To change the unit of measurement you use for pool length, see How do I change the units of measurement in my Fitbit account?
For more information please check: How do I track my swims with my Fitbit device?
Hope this helps!
> Swim.
@bobmunder, it has been a pleasure and I'm glad to know that your inquiry was resolved!
Thank you for marking the answer as best answer! This will allow other users with similar questions to find a faster response.
Have a great day!
Hi
i have looked and cannot swipe up on the swim app to be able to set the length of the pool, help!
thank you
Best AnswerHi Rach -
When you get to "Swim" - tap swim - then you'll see "full stats" - at that screen swipe up and you'll see "pool settings" - tap that - you'll see pool lengths - tap that and choose you length - you'll also see the settings for unit - either yards or meters
Hope this helps
Happy swimming
