How do I adjust the Inspire 2 Pool Length?
ANSWERED
How does the Inspire 2 track a 23 yard pool? I don't see a setting to adjust the pool length.
I can only select yards or meters.
1 BEST ANSWER
Accepted Solutions
@bobmunder thank you for reading the information!
Looks like you should be able to find the Pool settings option by doing the following:
  1. On your device, open the Exercise app
    Swim.
  2. Swipe up and tap Pool Settings.
Can you confirm if you're able to find this setting on your Inspire 2?
I look forward to your response.
Wilson M. | Community Moderator, Fitbit.
7 REPLIES 7
Hello @bobmunder, welcome to the community forums!
To change the unit of measurement you use for pool length, see How do I change the units of measurement in my Fitbit account?
For more information please check: How do I track my swims with my Fitbit device?
Hope this helps!
Thank you for the response. However, this does not answer my question.
This only addresses the unit of measure {Yards or Meters}. I’m looking to change the length of the pool that I use. I swim in pools that are different lengths. On the original Inspire there was a setting to change the pool length. Much like you can change the stride length for walking or running. I don’t see /can’t find the pool length option with the Inspire 2. I’m using an iPhone 12 Pro with iOS14.4
Munder
    Swim.
Mr. / Ms. WilsonFitbit - Thank you.
You have both answered and resolved my question and/or issue. I am now able to modify the Pool Length according to my workout.
I have voted for your Post and will flag it as best answer. Thanks again.
Munder
@bobmunder, it has been a pleasure and I'm glad to know that your inquiry was resolved!
Thank you for marking the answer as best answer! This will allow other users with similar questions to find a faster response.
Have a great day!
Hi
i have looked and cannot swipe up on the swim app to be able to set the length of the pool, help!
thank you
Hi Rach -
When you get to "Swim" - tap swim - then you'll see "full stats" - at that screen swipe up and you'll see "pool settings" - tap that - you'll see pool lengths - tap that and choose you length - you'll also see the settings for unit - either yards or meters
Hope this helps
Happy swimming
