10-23-2020 11:42
10-23-2020 11:42
The display on Inspire was too dull, couldn't read it, and sent it back.
Got the new Inspire 2, and the brightness was better. Charged it for the second time, and the brightness went to super dull.
Help.
How do I adjust it to BRIGHTER?
Thank you!
10-27-2020
17:05
13:57
10-27-2020
17:05
13:57
@ishwara A warm welcome to the Fitbit Community. Thank you for getting in touch about this.
I appreciate that you mentioned you received a new Inspire 2, if the screen is dim please check that the following settings are turned off:
- Dim Screen
- Sleep mode
These will be easily accessed in the Quick Settings, just press and hold the buttons on Inspire 2 and choose those. They shouldn't be illuminated to indicate that they aren't activated.
Let me know how it goes.
06-11-2021 10:54
06-11-2021 10:54
I'm having the same issue, the brightness isn't enough in the outside world. Both dim screen and sleep mode are off and no change. Is there anything else that can be done?
06-14-2021 12:39
06-14-2021 12:39
Screen wake comes up and it is almost not visible. What can I do to make it brighter. I can't tell what time it is when I am outside.
06-15-2021
18:12
08:57
06-15-2021
18:12
08:57
@{Cupcake} @Martha-R Welcome to the Fitbit Community.
Thanks for the settings checked. Since you've checked that Dim screen and Sleep mode are off, and your display isn't visible outside, please get in touch with our Support team, they'll be happy to help.
Hope this helps.
06-06-2022 13:54
06-06-2022 13:54
Having the same problem. Can't even see the display.
06-07-2022 08:26
06-07-2022 08:26
I also have this issue, I bought another kind but its not water proof,
So I'm doing a little digging to see if it can be fixed
JP
06-12-2022 01:55 - edited 06-12-2022 01:57
Try a different clockface - beware: many of the options show the minutes dimmer than the hour. However, no option is really bright enough.
06-12-2022 13:29 - edited 06-12-2022 13:30
There are some clock faces that might help the brightness, but in general it can't really be fixed.
Clock faces that might make it easier to see the display are Shifted, Just Time, and Glam.
Hope this helps. I have the same issue.
Sorry for replying to you @JumblyOne
06-13-2022 08:26
06-13-2022 08:26
I also have the brightness issue! I have checked all the settings and the dim is set to off and am unable to see the minutes while outside. I have also been unable to see a way to change my clock face with this fitbit. I had a Blaze from forever ago and it was wonderful but this Inspire two seems to be a giant pain. Someone help us fix this!!!
06-14-2022 02:08
06-14-2022 02:08
I find that TRON is working for me as the digits are thicker
06-15-2022 13:02
06-15-2022 13:02
TRON? What is tron and how do I change the display numbers?
Best Answer06-16-2022 01:42
06-16-2022 01:42
To change clock display :- On the app, go to your Account (from your profile picture), go to Inspire 2, view Gallery which should show the current clockface, choose different from Clocks.
Best Answer08-13-2022 16:03
08-13-2022 16:03
Checked to see these 2 items were turned off. They both were off and still the display is dim and not readable outside. What can I do to get it brighter.
12-18-2022 16:51
12-18-2022 16:51
Exactly the same issue as mine, the brightness isn't enough in the outside. Both dim screen and sleep mode are off and no change. I love my Fitbit BUT it’s useless outdoors as I can’t even see what’s written on the screen. It’s irritating to be honest.
