How to delete apps…
ANSWERED
I don’t understand how to delete apps for example the notifications and the phone gps…I don’t need/want these apps on my inspire 2 at all and it would be helpful if the app had a feature to remove apps in that way individuals like myself would see fit…but I’ve tried calling the company on the customer support line and they say by turning it off and on then off again…no I want it gone.
ps: the individual on the phone from the customer support from Fitbit was lovely and she had a lot of patience with me, and it’s not her fault that I’m picky as hell😂
1 BEST ANSWER
Accepted Solutions
The Phone GPS is off on everything and the exercise app is also off.
maybe I’m just being a little too cautious about it perchance, thank you for your helpful reply by the way!
2 REPLIES 2
Hi @Oliv3rr   I'm sorry, but Fitbit doesn't let users remove apps from trackers.
Can you describe your phone GPS issue a bit more?  The phone GPS is only used while use are using the Exercise app and if the setting is on.
Laurie | Maryland
