03-23-2019 07:58
03-23-2019 07:58
This tracker keeps lighting up at night when i move my wrist or when sitting with my meditation group.. I am looking for the settings to turn off Quick View.
I looked in my settings on the tracker but don't see a button. Does anyone know how I can turn this off?
If I can't stop this clock from activating will have to return it to Amazon and get my money back..
Thanks, Karl
Best Answer08-26-2019 07:09
08-26-2019 07:09
you may have to do it on your computer, in your FitBit Account. Some devices won't do it any other way.
Best Answer08-26-2019 07:12
08-26-2019 07:12
Go to your account on the website. My hubby has the same device, and that was how he had to change his
Best Answer08-26-2019 07:16
08-26-2019 07:16
hubby has a charge 2, it's in the Website,fitbit app, open fitbit app then click on fitbit top right, scroll down to quick view and turn it off (or on ) then sync, now you can only see it if you push button or tap(if turned off) (or turn your wrist, if on). Good luck!
Best Answer08-26-2019 07:25
08-26-2019 07:25
Best Answer08-26-2019 07:39
08-26-2019 07:39
Best Answer08-26-2019 07:56
08-26-2019 07:56
Super!!!
Best Answer09-03-2019 10:06
09-03-2019 10:06
Thank you! I had an Alta previously and this was easy and intuitive to do. Now I have an Inspire and have been removing my tracker at night because I couldn’t figure it out. Couldn’t use it for sleep tracking. Appreciate your help!!
Best Answer09-04-2019 08:13
09-04-2019 08:13
Glad it helped.
Best Answer09-04-2019 08:16
09-04-2019 08:16
Did you try from the FitBit website? Depending on your device, that could be your solution.
Best Answer10-07-2019 18:40
10-07-2019 18:40
Thank you Su-z-q1954! It worked...I held the button on the Inspire HR and tapped the light bulb so there was a line through and now it doesn’t light up at night!
FITBIT app developers it would be good to add this tip to the Discover Sleep section. Something like Tip: For a good nights sleep it’s important to turn off electronics. To turn off your Fitbit display hold the button down and tap the light bulb...Sounds like many people have returned this model because they couldn’t figure out how to turn the display off.
10-09-2019 01:42
10-09-2019 01:42
Sounds like lots of people have this issue, whew it's not just me.
My previous Fitbit was a charge 2 and i could set it on my computer to not use quickview. It seems odd that Fitbit haven't made it easy for people to be able to turn this annoying feature off during night time hours. seems like a pretty easy fix that lots of people would benefit from. So why haven't fitbit done it? Having to go manually onto my device on my wrist is too much thinking. would prefer to have quickview during the day but not at night.
Best Answer12-17-2019 16:10 - edited 12-17-2019 16:11
Thank you!!! Yesterday I noticed Quick View was no longer working and thought it was broken. I knew there was a way to turn it off, and thought I'd accidentally done that. I thought it was in the app, but couldn't find it. Apparently, I did turn it off. Probably when checking my battery life. I'm so glad my Inspire is not on the fritz.
12-18-2019 09:07
12-18-2019 09:07
Isn't it great when we find out we aren't nuts!!🤣🤗
Best Answer12-18-2019 09:59
12-18-2019 09:59
Thank you!!!! I was wondering why it wasn't working and I couldn't find the setting!
Best Answer12-19-2019 06:12
12-19-2019 06:12
Glad I could help. Happy Holidays🤠🌲
Best Answer01-06-2020 06:40
01-06-2020 06:40
Where did you find the quick view settings on your fitbit inspire hr
Best Answer01-06-2020 06:42
01-06-2020 06:43
01-06-2020 06:43
Thank you
Best Answer01-06-2020 07:30
01-06-2020 07:30
Chooper12, it's where you find your battery life, looks like a light bulb, if there is a line thru it, your watch won't light up when you move: helpful if it disturbs you at night. Other quick settings are in the app. things such as clock faces etc. Somethings are only on the Fitbit website
Best Answer01-19-2020 20:35
01-19-2020 20:35
This worked. Thanks!
