01-30-2024
07:45
13:14
JuanFitbit
01-30-2024
07:45
13:14
JuanFitbit
I'm using the Inspire 2. "On wrist/clip" is the only option I select from quick settings which is the last tile in section. Scrolling all the way down to select the option and then again confirming my action takes time. Is there any other way for the switch On wrist/clip to be super convenient and quick.
Moderator edit: format
@Iamaneesh , A warm welcome to the Community! Thank you for your message and feedback.
The fastest way to turn Clip/Wrist mode on/off is over the quick settings. At this moment there are no options to personalize it (reorder the tiles)
I invite you to publish your question as an idea on our Product Feedback board. Please take a moment and give us your comments.
If you find a similar suggestion from another member of the community, you can vote for their suggestion and add your comments. We hope to see you there!
