07-05-2022
05:43
22:19
07-05-2022
05:43
22:19
I have tried everything it says online to no avail. If I change the face time it will work for a second or two then go black again. It is fully charged and does not vibrate or show a smiley face. It does however sync with my phone app so I do have data. Any ideas??
@Dellarobia , I was guessing you had probably tried the restart. But what I was trying to suggest is that you might need to hold the button for a LOT longer than they suggest. My daughter in law (and others that I know of) have had the blank screen issue and holding the button for more like a full 30 seconds did solve it.
Of course that really LONG restart might not help. But probably worth a try. If not, please do get in touch with Fitbit Customer Support on contact.Fitbit.com. They will let you know your options.
Hi, @Dellarobia , have you given your Inspire 2 a restart ? Sometimes you have to repeat this a couple of times, and also have to hold the button for significantly longer than the recommended 5 seconds.
Im having this issue too
Resets whilst on charge. Shows the smiley face. Changing the clock face shows a loading bar. But other than that the screen is completely blank.
Its not water locked. Resetting many times doesn't help.
Best Answer@Dellarobia , I was guessing you had probably tried the restart. But what I was trying to suggest is that you might need to hold the button for a LOT longer than they suggest. My daughter in law (and others that I know of) have had the blank screen issue and holding the button for more like a full 30 seconds did solve it.
