11-21-2023
07:34
02:27
11-21-2023
07:34
02:27
Inspire 2 pinch feature not working. Tap and swipe on the screen seems to be OK but the pinch option suddenly stopped working with my latest charge/update on the unit. Any ideas?
Hi there, @mds33. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Inspire 2 screen is not working properly. I'll be glad to help you with this!
To better assist you, may I know what you mean by "pinch"? Are you referring to the screen wake feature? If so, please go to your quick settings and check if the screen wake has been accidentally been turned off. To do so, swipe down from the clock face on your watch to access the quick settings. Here you can change whether the screen turns on when you turn your wrist. For more information, see How do I navigate my Fitbit device?
If the above doesn't describe your issue, please let me know what you mean by pinch so I can go from there.
Hope that helps.
@mds33 Thanks for getting back and sharing those details in your previous post.
If you haven't done so yet, please try placing both forefinger and thumb each side of face and pressing gently, also make sure to cover the entire button with your finger.
Hope this does the trick for you!
@mds33 I'm sorry for the misunderstanding. I've updated my post above.
In addition to the steps you've done so far, please restart your Fitbit device as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
If the above doesn't work, please make sure Do Not Disturb and Sleep Mode are turned off on your Fitbit device as any of these feature will prevent your Inspire 2 from turning on when you move your wrist.
Let me know how it goes.
@mds33 Thank you so much for trying the steps I provided above.
I've created a case to get you in contact with our Support Team about this issue. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you shortly!
We hope to get you back on track soon!
@mds33 Anytime! We look forward to getting your issue solved.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
