03-05-2022
01:24
22:48
03-05-2022
01:24
22:48
Hi my 11 month old inspire too has become really dull on the time front screen that it is no longer readable. I have checked the settings and all are well.
please has anyone got any ideas? Many thanks steffi
03-12-2022 11:51
03-12-2022 11:51
Hi, welcome to the Fitbit Community forums, @steffiamelia.
Thank you for sharing that you've been having this inconvenience with your Inspire 2 and that you already checked the brightness settings.
In addition to the brightness, please make sure that you've tried the restart procedure as described in this article. If you haven't done so already, please check if you have the Do Not Disturb Mode and Sleep Mode features activated, as they automatically make the screen darker as well.
Hope this helps, I'll be around.
Best Answer03-12-2022 11:51
03-12-2022 11:51
Best Answer07-11-2022 15:57
07-11-2022 15:57
good advice if you can see the screen! the screen is too dark to read or adjust the settings.
I wish there was a way to adjust the settings from my dashboard!
Best Answer07-21-2022 10:59
07-21-2022 10:59
@mb0061 Thank you for sharing your feedback and experience with this.
Unfortunately these settings I mentioned are only available through the Fitbit app. If the screen is too dark to complete any of the steps mentioned earlier or if you were able to complete the steps and the screen continues to be dark, I do recommend that your get in touch with the Customer Support team for further assistance with this. They will let you know how to proceed.
The best way to get help for this problem is to chat with us online or give us a call. You can click here to get connected.
See you around.
Best Answer07-21-2022 18:02
07-21-2022 18:02
Does not work, i cant even reset it anymore to the point where the time returns. When you try to reset it the smiley face pops up 2 or 3 times and it goes dark.
Best Answer07-21-2022 23:22
07-21-2022 23:22
07-24-2022 11:50
07-24-2022 11:50
same here! the wrist candy tracks, but the screen is useless. I cannot even see the clock. Can only see my progress on my phone or dashboard.
This is the 4th model of Fitbit I have had since I started tracking my steps; they never last more than 15 - 18 months, Time to move on to a different brand
08-06-2022 12:20
08-06-2022 12:20
Hi, thank you for all your replies and for confirming that you already all the steps suggested.
@Mzharris77 I've been informed that you already contacted the Customer Support team for further assistance with this and it seems they've provided you with some instructions. In this case, they will let you know how to proceed.
@steffiamelia @mb0061 I appreciate all the information provided and for sharing that you're still experiencing this problem. In this case, I do recommend that you continue the communication with the Customer Support team so they can let you know about the next steps. You can click here to get connected.
Thanks again for all your feedback and comments about this.
Best Answer02-21-2023 19:28
02-21-2023 19:28
Looks like i am having the same problem again i have tried to reset several times and even though i get the smiley face it still flashes
Best Answer02-22-2023 17:21
02-22-2023 17:21
turn OFF Dimscreen setting
07:05
19:57
EstuardoFitbit
03-08-2023
07:05
19:57
EstuardoFitbit
@Mzharris77 Thanks for sharing that you've been having a similar problem.
If you're still able to see the logo it's possible that you have the Dim screen setting on, as @jt2022 mentioned earlier.
Swipe down from the device's clock, and tap on the Settings icon. Toggle Dim Screen to Off.
Best Answer03-08-2023 07:44
03-08-2023 07:44
that was the whole problem, I was unable to see the screen to adjust the settings.
In frustration, I finally gave up and threw the fitbit into the garbage.
4 different models in 5 years, each with their own shortcomings and failures. I am done with FITBITs.
03-08-2023 16:10
03-08-2023 16:10
11:19
19:57
EstuardoFitbit
03-19-2023
11:19
19:57
EstuardoFitbit
@mb0061 Thanks for taking the time to share your comments about this and I'm sorry to see you no longer have your device. The team continues to work to improve the quality of products and services.
@jt2022 Thanks for sharing your experience with this as well. I'm sure it will be useful for other users as well.
Best Answer06-13-2023 07:02
06-13-2023 07:02
I’ve been experiencing the same issue, I’ve noticed it in the past couple of months. I’ve checked all the settings, it’s not in dim mode, not in sleep mode, and have rebooted several times. If I’m inside it’s okay (but not great), but outside it’s completely unreadable. Are there any other tricks to try or settings to check?
06-13-2023 07:21
06-13-2023 07:21
06-13-2023
07:29
16:01
EstuardoFitbit
06-13-2023
07:29
16:01
EstuardoFitbit
best solution I found was to close my eyes, cut my losses, and throw it in
the trash!
Haven't looked back
Moderator Edit: Removed personal information
06-13-2023 07:40
06-13-2023 07:40
07:57
09:50
EstuardoFitbit
06-13-2023
07:57
09:50
EstuardoFitbit
nope, no more fit bits for me!
The Inspire was my 4th or 5th model for me in about as many years. They
all failed me after just a few months or so. The Inspire, which was the
most expensive, barely made it to a year.
06-16-2023 13:43
06-16-2023 13:43
