04-26-2021 23:51 - edited 04-26-2021 23:51
I like the dim screen setting but it's useless in sunlight. So I have to set it to bright every morning and dim it at night.
Why can't you just use the time of day to do it? It's useless otherwise. I either have to do it manually or keep it bright which is too much at night.
PS Where is the Inspire 2 forum?
Best Answer04-27-2021 06:50
04-27-2021 06:50
Hi, @AngusBeef if you set up a sleep schedule on your Inspire 2 the screen will automatically dim at night and then return to your bright setting when sleep mode is turned off. To set up a sleep schedule on the main (clock) screen swipe down until you find the gear icon (settings). Tape on the gear icon and then tap up until you see “sleep interval”. Tap on that and choose your start and end times.
You can find the Inspire 2 forum under the main forums as the Inspire 2 is a currently fully supported device.
I hope this helps!
04-27-2021 06:50
04-27-2021 06:50
I hope this helps!
04-27-2021 07:03
04-27-2021 07:03
Thanks that's useful but won't help me. I don't want the other sleep features.
