05-17-2023 07:17
05-17-2023 07:17
My son has an Inspire 2 watch and recently the screen began to become more and more dim over a week or two period. It's now so dim that it can't even be seen in the dark. I previously made sure to check the Dim and Sleep settings, so I know those two items are not the cause. It seems as though the display itself has just completely faded. In the dark, you can see a faint display on the top and bottom edge. Anyone else have a similar experience?
05-30-2023 11:43
05-30-2023 11:43
Thanks for getting back to us and for following advised troubleshooting steps @Stillteaching.
I went ahead and created a case on your behalf and a customer support representative will get in touch with you.
You can check your email.
05-17-2023 13:22
05-17-2023 13:22
@Gall22 Have you tried restarting it? That's usually the first thing I do when I encounter unexpected behavior from my Fitbit.
If that doesn't help, you might consider changing the watch face. Sometimes that will cause the display to start working properly again. If that fixes the problem, you can change it back to the preferred watch face afterwards.
Amanda | Wyoming, USA
Pixel Watch 3, Inspire 3, Sense | Android
05-18-2023 05:37
05-18-2023 05:37
@alexthecat thanks for sending your suggestions. I tried each of these items last night, but the display is still not showing. It's now too dim to read even in the dark.
05-19-2023 09:10
05-19-2023 09:10
@Gall22 I'm sorry to hear that. Do you know how long he has had his Inspire 2?
05-19-2023
16:11
17:54
AndreaFitbit
05-19-2023
16:11
17:54
AndreaFitbit
I also have a Inspire 2. I have to talked to numerous tech from Fitbit. Most have no idea what they are talkijg about. There is no Dim setting on our two units. They told me you don't have to hold both side to open the unit. They told me just go to 'Settings' and then to the 'Dim setting. This Unit does NOT have a Dim Setting. It des have a Quick Settings and they had no idea what that was or where it is. They will not replace the new unit.
Never again and tell every one what Fitbit is.
Moderator edit: word choice.
05-19-2023 17:11
05-19-2023 17:11
@BHJH here is a video that shows how to enable and disable the Dim setting on the Inspire 2: click here
That is exactly how it works on my Inspire 2.
05-20-2023 08:12 - edited 05-24-2023 09:05
Welcome to the Fitbit Community, @Gall22, @BHJH. I'm sorry to hear that your Inspire 2 display is too dim to see.
@Gall22, thank you for checking your tracker's settings and for confirming that you have followed advised troubleshooting steps.
@BHJH, I'm sorry to hear about your experience. Thank you for your feedback and comments.
@alexthecat, thank you for your advise.
@Gall22, I went ahead and created a case on your behalf. Please check your email.
We look forward to get you back on track.
05-20-2023 09:12
05-20-2023 09:12
05-20-2023 09:57 - edited 05-24-2023 09:06
Welcome to the Fitbit Community, @Patwalker. I'm sorry to hear that you need to go to your clothes closet to view your Inspire 2 screen.
Could you please confirm that you have restarted your tracker and changed the clock face?
05-21-2023 05:06
05-21-2023 05:06
Thanks everyone, for your help and replies. I appreciate it.
05-23-2023 08:45
05-23-2023 08:45
Thanks for getting back to us @Gall22.
You're very welcome.
05-26-2023 11:35
05-26-2023 11:35
Same here; dim screen & won’t tap to open.
Any suggestions?
05-26-2023 12:45
05-26-2023 12:45
Welcome to the Fitbit Community, @Stillteaching. I'm sorry to hear that your Inspire 2 is dim and that it won't tap to open.
05-26-2023 13:23
05-26-2023 13:23
05-27-2023 01:29
05-27-2023 01:29
I have had 2 fitbit watches both screens went blank after 2 years, have been told to go into settings but how can I when the screen is completely black and I live too far away from you to climb into your closet lol
05-27-2023 09:43
05-27-2023 09:43
Thanks for getting back to us and for describing what's happening with your Inspire 2 @Patwalker, @Silverstud.
Please verify that you have restarted your tracker and changed the clock face?
05-30-2023 06:38
05-30-2023 06:38
05-30-2023 11:43
05-30-2023 11:43
