01-03-2024
10:36
07:50
ManuFitbit
01-03-2024
10:36
07:50
ManuFitbit
Inspire 2 stopped showing my heart rate a couple of days ago, I bought this to follow up my heart because I have irregular heart rate problems. that feature stopped working a month ago with version 4.04 and now I can not even see my heart rate anymore, fix this urgently please. button wearing on the wrist is selected, so that is not the problem.
Moderator edit: clarified subject.
01-03-2024 14:11
01-03-2024 14:11
@Vdbson , A warm welcome to the Community! Thank you for your message.
To avoid confusions, could you please specify if the heart rate data missing is on the Fitbit App or on the Inspire 2?
Does the tracker show the heart rate readings?
Are the green LEDs blinking?
This will help me determine if the issue is on the tracker or the Fitbit app.
Best Answer01-03-2024 16:55
01-03-2024 16:55
I had the same thing happen and they said it was a known issue 😞
Best Answer01-05-2024 04:55
01-05-2024 04:55
issue is on the fitbit app.
Best Answer01-07-2024 04:15
01-07-2024 04:15
Can I have a reply please, issue is on the fitbit app , the tracker shows heart rate but on the app the heart rate is grey.
Best Answer01-07-2024 10:41
01-07-2024 10:41
@Angiebubs @Vdbson . Thank you for your messages and confirmations.
As you mentioned, the issue is on the Fitbit app. Our team is aware of the situation and working on a solution for it.
Hopefully it will get solved soon.
I'll be updating the thread should I receive further information
