09-29-2022
16:11
21:04
09-29-2022
16:11
21:04
My Inspire 2 has stopped syncing with my iPad. I have tried turning the iPad on and off. I have also tried turning Bluetooth on and off as well as asking my iPad to forget the device and then reconnecting but still no luck. Any suggestions?
09-30-2022 23:55
09-30-2022 23:55
I'm not sure where you're looking in that help file but the restart instructions for the Inspire 2 are:
The restart process is safe and you won't risk your data.
Best Answer09-30-2022 00:44
09-30-2022 00:44
You mention restarting the iPad but have you tried restarting your fitbit? It does no harm and can sort out all sorts of issues. Here's how: Help article: How do I restart my tracker?
Best Answer09-30-2022 16:57
09-30-2022 16:57
Best Answer09-30-2022 17:02
09-30-2022 17:02
Thanks Steve.
When I follow the link, it tells me to go to settings to turn on and off my Fitbit. The only option I get is to reboot. Is this what I should do? I would prefer not to lose my data. Thanks
Best Answer09-30-2022 23:55
09-30-2022 23:55
Best Answer10-02-2022 23:30
10-02-2022 23:30
Best Answer10-04-2022 20:26
10-04-2022 20:26
What finally worked for me was reinstalling the app on my phone.
Best Answer12-10-2022 22:35
12-10-2022 22:35
Have done that and it is still not syncing
12-16-2022 12:21
12-16-2022 12:21
Same here. Neither restarting nor reinstalling the app on my Android phone solved the problem. Still won't sync.
12-16-2022 12:22
12-16-2022 12:22
Ditto Eileen-C
Best Answer12-23-2022 10:07
12-23-2022 10:07
I don't have the same size USB point on my phone or tablet as the charger, so can't connect the charger to my device! What else can I do? My inspire 2 hasn't been syncing for 9 days!!!
