12-21-2021
19:10
22:58
12-21-2021
19:10
22:58
The fact that YojanaFitbit closed the thread about the constant problems with Water Lock activating inappropriately without providing a workable solution says everything we Inspire users (aka sufferers) have been dealing with for months. Furthermore, the comment to "please try to turn your wrist toward your body since water lock doesn’t always unlock if the device isn’t in this orientation" is utterly inane since one's wrist is turned toward your body in order to manually unlock it. It also doesn't address why Water Lock turns on when the Inspire is in the clip (which is how I primarily use it). The fact is, the software team can't or won't try to come up with an option for users who do not swim or shower with the Inspire to disable Water Lock; that is all that we hundreds of commenters have asked for. And the recommendation to contact support is just totally frustrating. I have called support more than once. The first time, the person said my initial Inspire was apparently defective and sent me a new one. After I called because of the same problem with the new one, I got all the canned responses that don't work... and an offer of a Fitbit watch, which I declined because I prefer the clip. So unless you want to get another Inspire or a different Fitbit product that won't work any better than the one you have, I strongly suggest not wasting your breath calling support.
Hi @ADKzip I've not had a problem with water lock and my Luxe, but I wanted to post a link to the thread that was closed. A family member has the Inspire 2 and uses a clip. I'll have to ask them if they've had any problems. Sorry this is happening and hope that it can be resolved for you.
12-21-2021
19:42
08:32
12-21-2021
19:42
08:32
Hi there, @ADKzip. Thank you for sharing your comments about this issue with your Inspire 2. We‘re taking your comments and sentiments in regards to our products and services into consideration. @Odyssey13 Thank you for jumping in.
We understand that the outcome of your case with our Support Team is not fulfilling your expectations, but keep in mind that every case is completely different from the other's, thanks for taking the time to share your experiences and feedback. For more information about the outcome of your case, please get in touch with our team again. I've updated this information in your previous case.
Thank you for your understanding.
Best AnswerI also use the clip, except when sleeping and water lock turns on every time I switch from the wristband to the clip and vice versa; most times, it's easy to switch off after making the transfer but sometimes it just goes nuts and blocks me from enabling the wrist or clip until I plug it in to force a reset. And on a couple of occasions, it blocked the reset until I plugged and unplugged it several times!
I have the same issue with water lock constantly turning on multiple times a day. I wear it on my wrist and I am double tapping it many times a day to unlock "water lock". It's to the point I find this new Fitbit to be useless. I tried support and got no resolution.
I have the same problem and I have only had my inspire 2 for 1 week. I have daily trouble with the water lock several times a day.
Maybe stop flexing your wrist at all. Or don’t wear your Fitbit. These are the only 2 solutions I have found that work. (I hate the water lock feature!!)
