10-03-2020
16:53
17:25
LizzyFitbit
10-03-2020
16:53
17:25
LizzyFitbit
I've had this fitbit less than a week, and have been swimming with it 3 times. Every time I tell it I'm swimming it goes into waterlock - great - but when I stop swimming I can never get it OUT of water lock. The screen won't even show up. AND it never sends the workout to the dashboard so I can see it - it's like it just disappears and I end up having to log it manually anyway. What is the point of having swim as an exercise to track if it won't track it. Because I swim is the ONLY reason I got this one.....help - I'd really like it to work properly - how do I get it to record the exercise, and how do I get it to come back from water lock?
04-16-2022 20:41
04-16-2022 20:41
Doesn’t work. VERY UNHAPPY! No matter how I tap, it doesn’t work. Doesn’t track sleep either. Do not recommen6.
05-08-2022 18:28
05-08-2022 18:28
Experienced this too after my last swim and I just charged it and and tapped it while it's charging and that helped take it out of water lock.
Best Answer07-23-2022 03:50
07-23-2022 03:50
As you can see from the comments, this does NOT work.
Just got my first fitbit. Not impressed that a feature I plan to use regularly clearly has performance issues. Very disappointing.
07-23-2022 20:39
07-23-2022 20:39
Thank you, worked perfectly!!
Best Answer08-14-2022 05:30 - edited 08-14-2022 05:38
I followed DoreLacroix's suggestion for being stuck with a non responsive (i.e. black screen but green sensor light on) Fitbit Inspire 2: double tap the screen and then squeeze it. That brought the Fitbit back to life.
PS it's obviously a firmware coding design flaw and it's still here two years after release. When Sleep mode is active and water lock gets activated the screen won't wake to allow for water unlock even though it's still checking for a double tap. You'd have thought they would've fixed this very simple to fix flaw with a firmware update since the device is two years old. All you need on the programming side is a simple if-statement when water lock gets activated:
if isWaterLock is True set isSleepModeActive to False.
Best Answer08-29-2022 03:04
08-29-2022 03:04
exactly the same reason I returned my first one! Second one seemed better and I rarely use the water lock but just remove the device but this time I showered with it on and can’t get it working again. May have to find the directions about rebooting. You’d think the could fix the problem!
Best Answer10-18-2022 13:19
10-18-2022 13:19
This didn't work.
The only thing that worked is to restart the fitbit
". If Inspire 2 is unresponsive: 1. Connect Inspire 2 to the charging cable. For instructions, see "Charge your tracker " on page 7. 2. Press and hold the buttons on your tracker for 5 seconds. Release the buttons. Whenyouseeasmileyface and Inspire 2 vibrates, the tracker restarted. Restarting your tracker doesn't delete any data."
Best Answer10-19-2022 15:24
10-19-2022 15:24
Inspire 2 will not come on after swimming even after drying it and charging. And when I try to charge it it only gets burning hot to touch. Some one please help
Best Answer10-22-2022 12:08
10-22-2022 12:08
Thanks .... Palm works!😅
Best Answer11-05-2022 20:03
11-05-2022 20:03
Does anybody know if the new Inspire 3 has the same water lock problem, or if they fixed it?
Best Answer01-29-2023 18:00
01-29-2023 18:00
my Fitbit is stuck in swim tracking mode. I double tap to turn off water lock, and that works. then I touch both sides at the same time to stop tracking, and the Fitbit does not respond. then it goes back into water lock and i start the same frustrating cycle again
Best Answer04-02-2023 08:33
04-02-2023 08:33
You cannot tap the screen because the device is 100% unresponsive. The only working solution is to connect it to a charger.
06-21-2023 11:20
06-21-2023 11:20
it worked for me, thank you
Best Answer06-23-2023 09:04
06-23-2023 09:04
Hi Everyone.
In order to have the community better organized, I'll proceed to close this thread.
If you want to share ideas, have any inquiries or need help about other concerns please visit the community.
