Inspire 24 Hour Clock
ANSWERED
Can anyone assist to setup my inspire with 24 hour clock? Thanks
1 BEST ANSWER
Accepted Solutions
You can choose between 12 and 24 hour clocks in your profile settings at https://www.fitbit.com/user/profile/edit
Once changed and saved, the next time you sync your fitbit will be updated
6 REPLIES 6
Hi Steve - thanks a lot. Solved a very frustrating problem!!!!!
Doesn't work for me 😥
I make the change, click "Submit", synch and... it's still 12hr clock not 24 😔
@CaronLel I wonder if your choice of clockface is overriding the setting. Perhaps try a different clock to test?
Brilliant, thanks so much. Was so simple when you know how. Spent hours on this 🙄
That worked, thank you.
seems absurd that among the myriad of things you can customise on the device and phone app, a simple time display option isn’t one of them.
hey ho  ¯\_(ツ)_/¯
