05-08-2021 21:43
05-08-2021 21:43
Up until ~ 04/26/2021 I had no problem with the GPS Tracker route diagram and measured distance on my Inspire. Since then, neither has worked properly. The route diagram misses a large section of my walk and connects where the Tracker stopped tracking to where it started up again, with a straight line. The distance shows ~ half of what it should and of course the pace is ~ double what it should be.
05-09-2021
10:34
08:03
05-09-2021
10:34
08:03
@M_A_M Thanks for joining us!
The Inspire doesn't have a GPS chip, it uses your phone's chip to track this information. So I suggest you clear the link between your phone and your tracker by doing the following:
Hope this helps.
Best Answer05-12-2021 10:59
05-12-2021 10:59
