09-13-2019 08:54
09-13-2019 08:54
I just switched from an Alta HR to an Inspire HR. I love it but my Alta showed my battery life on my band and the inspire doesn’t seem- i have to go into the app. Is there a way to get it on the device? Also should I keep all day sync on or off? Any advantages one way or the other?
Best Answer09-14-2019 03:38
09-14-2019 03:38
Hi @BethM42 Yes the Inspire is a great little tracker! I leave all day sync on these days as I like it to sync in the back ground, but it is entirely up to you. You will get a slightly better battery life with it off, but try it both ways and see which you prefer.
As far as the battery level - easy! With the clock face displayed, give a long press on the button to display the quick menu and the battery level is right at the top.
Helen | Western Australia
