03-24-2020
18:50
05:49
AlejandraFitbit
03-24-2020
18:50
05:49
AlejandraFitbit
Crossed time zones in recent travel. Worked well going but on return home did not change time zones. Is there a way to reset the watch? I've tried rebooting several times.
Best Answer04-10-2020 05:50
04-10-2020 05:50
It's great to see you here, @Qt1.
I am sorry for the delay in respond, due to recent events affecting our operations, support options are limited and wait times are longer than usual.
Thanks for troubleshooting this timezone issue, I would like to know if you keep experiencing this? If so, I recommend changing the timezone to a completely different one, sync the device, put the correct time and sync again.
To change the time, follow the steps in the article: How do I change the time on my Fitbit device?. Also, make sure that the device you are using for this has the correct time.
Let me know how it goes. 🙂
