11-18-2021
20:41
13:06
AndreaFitbit
11-18-2021
20:41
13:06
AndreaFitbit
My HR has stopped syncing
Best Answer11-19-2021 00:22
11-19-2021 00:22
The usual things I try when I get syncing issues are:
If none of those ideas work for you then it’s probably best to contact customer support via: contact.fitbit.com
11-22-2021 14:39
11-22-2021 14:39
I have tried all the fixes recommended and more, you sent me a replacement unit offer number 41681157 in July this year after experiencing the same problem clearly your system has a fault .
The tracker displays all info but does not sync . again when i try to sync and go to Bluetooth setting in my phone says its connected.
the input code registers but times out with the "abort " message . ????? what next .????
