07-07-2019
12:50
08:59
AlvaroFitbit
07-07-2019
12:50
08:59
AlvaroFitbit
Fitbit Inspire (2 month old ) does't work anymore, not charging, no display, no green light too....
09:03
10:01
07-08-2019
09:03
10:01
@SergIrinaNL, welcome! It's great to see you around!
Let me help you with your non-working Inspire HR. If the device isn't charging then the display nor the green lights will work so lets address this issue. Try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves.You can also find additional suggestions here.
09:03
10:01
07-08-2019
09:03
10:01
