03-02-2020 10:16
03-02-2020 10:16
Hi, I’ve had my Fitbit Inspire HR for approximately 9 months now. I wear it everyday and have not encountered any problems with it until it just completely stopped working. The red/green light also stopped turning on even if I charge it. Any idea what this could be? I’m quite disappointed as it didn’t even last me a year.
11:52
06:02
03-03-2020
11:52
06:02
@Joycecrls It's great to see that you've visited the Fitbit Community!
Let me help you with your unresponsive Inspire HR and thank you for charging it. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help your tracker charge.
Let me know how it goes.
Best Answer03-03-2020 14:33
03-03-2020 14:33
Best Answer03-03-2020 14:34
03-03-2020 14:34
Hi thanks for getting back to me. I’ve tried everything you said but still nothing happened. Is there anything else I can do?? Please let me know
08:37
06:02
03-05-2020
08:37
06:02
@Joycecrls thank you for the update and sorry for the delay in mine.
Since the issue persist I have created a ticket so our Support team can further assist you via email.
Keep me posted.
Best Answer03-05-2020 12:13
03-05-2020 12:13
Im having the same problem only had my fitbit for 2 months!
First the sleep icon now this, Very dissapointed.
