Inspire HR stuck in setup screen loop
ANSWERED
I bought a new fitbit (an Inspire HR) to replace my old flex one, which my new laptop can't seem to find/pair with. Having set up my new fitbit so that the app syncs with it, the fitbit itself shows nothing but a horizontal line across the centre of the screen. No clock. No swiping up or down, nothing. This is a straight out of the box, brand new fitbit. I have reset it 5 times now, following the instructions found in the help section and still nothing. Due to no swiping I can't reset to factory settings. What can I do to get this sorted?
EDIT: got through to live chat. They were very helpful and have helped me order a replacement under warranty.
1 BEST ANSWER
Accepted Solutions
This happened to me and I was able to fix it by chatting with support. I tried to setup the device using the Windows Fitbit app for my PC - which seems to have a bug in it. The white bar across the screen is the progress bar for installing updates. I was able to solve by using a friend's phone by doing the following:
  1. On a phone, install the fitbit app and sign in - or if using friend's phone, log out of their account and sign in with your account.
  2. Reset the fitbit if needed (see https://help.fitbit.com/articles/en_US/Help_article/1186.htm)
  3. Then add the Inspire HR from the mobile device - this time it should download and install updates and break out of the setup loop.
Hope this helps.
5 REPLIES 5
Welcome to the Fitbit Community, @Rokkan0311.
In case you have some spare time, I would like to invite you to visit our Discussions board where you can share your experiences, make new friends and create new topics.
Keep on visiting the forums. Happy stepping!
This is the second Fitbit I have sent for and only get flat bar on the middle of screen.  I was also on live chat regarding the first Fitbit I purchased but got no answer to the problem.  I am now going to contact Amazon for a second and final time to collect yet again a faulty Fitbit, but this time I will not be asking for a replacement>  I feel very let down with this product and Help Centre.
got my replacement fitbit at stupid o'clock (7:18) this morning. Same issue as the first one. Tried the same technical steps, and nothing doing, it doesn't want to work. Think I'll be looking for a refund and going elsewhere. Can't afford the price tag for two pebbles that don't do anything.
Hope this helps.
Thanks for the reply, but I sent both of the pebbles back to Fitbit and used the refund to buy another brand instead.
