01-24-2021
05:29
06:23
JuanJoFitbit
01-24-2021
05:29
06:23
JuanJoFitbit
Having problems syncing sleep score from my iPhone to Fitbit Inspire HR. iPhone is able to reflect sleep score but even after resetting Fitbit multiple times, sleep icon remains dark.
Moderator edit: format
Best Answer01-24-2021 14:19
01-24-2021 14:19
Do you see simple sleep, or sleep stages, @John88Fit no sleep stages, no sleep score.
Best Answer01-24-2021 18:28
01-24-2021 18:28
Best Answer01-24-2021 19:25
01-24-2021 19:25
Looking at the user manual for the inspire HR, page 16. I don't see any place in the Inspire HR where it should show the Sleep data
Are you sure you have the Inspire HR, with only one side button, and not the Inspire 2 with the tactical button on both sides?
Sometimes a second sync is needed to get the sleep to display on the tracker.
Best Answer01-24-2021 19:50
01-24-2021 19:50
