02-18-2021 12:17
02-18-2021 12:17
Hi! I'm having a couple different problems with my Inspire HR, and have tried a few things but none of them have worked.
The first is that none of the exercise shortcuts will start - I can navigate to them, and change the goal settings, but they will not react when I tap the start button. I have already tried removing these in the phone app, syncing it, and adding them back. Nothing changed.
So, I went to try a hard reset on it, and found that is also not responding. I navigated into the settings app and the option for "clear user data" is there, but the icon for it is greyed out and does nothing when I tap it (the "reboot device" option is also like this). After this, I tried holding down the left side button to trigger a soft reset - this worked and the smiley face appeared on the screen, but after checking through everything the issues are still there. I've searched for a bit and have yet to find a help article or thread that doesn't tell me to clear user data, which I'm seemingly not able to do.
Fyi the fitbit at the moment has about 80% battery. Also, it is auto-tracking exercise still, I just can't trigger it manually (like I would using the Yoga setting since that isn't auto-tracked).
Best Answer02-18-2021 13:42
02-18-2021 13:42
I am surprised you would find anything recommending you clear user data. Can you share references?
Best Answer02-18-2021 13:54
02-18-2021 13:54
The main place I saw that was here, but I think there might've been one other as well: https://community.fitbit.com/t5/Inspire-Inspire-HR/Inspire-HR-won-t-press-start-for-workouts/td-p/43...
A lot of them didn't say that, though, and only recommended removing and re-adding the shortcuts in the app.
02-18-2021 14:08
02-18-2021 14:08
Thanks for sharing that link. I am surprised to see that from a Fitbit moderator but i certainly won't argue with that.
02-22-2021
11:39
16:26
02-22-2021
11:39
16:26
@larosh713 It's nice to have you on board!
Let me help you with this and thank you for troubleshooting this issue. This not a normal behavior from your device and since the issue persists I suggest you contact our Support team for further assistance. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
@JohnnyRow thank you for your help here.
Hope this helps.
Best Answer12-19-2022 10:54
12-19-2022 10:54
I JUST ENDED A CHAT WHERE I WAS TOLD TO DO THE SAME THING FOR THE SAME PROBLEM, WHEN I HOLD IN THECLEARDATA SCREEN IT DOES NOTHING BUT JUMP ALL OVER (THINK CHATTER)
Best Answer12-19-2022 10:55
12-19-2022 10:55
HAHAHA I TRIED THAT 3 TIMES AND GOT EXACTLY NO WHERE.
