09-01-2020 04:45
09-01-2020 04:45
I set my Inspire HR to 'sensitive' thinking it would better read the data, but decided I didn't like it flashing on at random times at every wrist movement, esp. at night. I changed the setting online back to 'normal' but it is still acting sensitive, randomly flashing on. What else can be done to make it 'normal' again?
09-02-2020 16:26
09-02-2020 16:26
So it was the Sleep Sensitivity setting.
The watch lighting up when you turn your wrist is called 'Screen Wake'. To turn that off, hold in side button a few seconds; look for 'Screen Wake' below battery; tap to toggle off or on.
09-02-2020 12:15
09-02-2020 12:15
Could you clarify the "sensitive" setting? Did you find this on the tracker? And was it called anything besides "sensitive"? The only setting I can think of offhand with a sensitivity is sleep setting, which has nothing to do with screen coming on, and is ignored with heart rate sensors.
09-02-2020 16:09
09-02-2020 16:09
Under Settings, under Sleep Sensitivity, there are two options: Normal and Sensitive. However, under Sensitive, the watch kept flashing ON every time I moved my wrist, night AND day. So I changed it back to Normal setting, but it's still flashing randomly. I am 'pretty sure' that is the only 'setting' I've fiddled with but not positive.
09-02-2020 16:26
09-02-2020 16:26
09-02-2020 16:59
09-02-2020 16:59
Thank you so much! I think I must have activated that by accident while fiddling with all the settings! Live and learn.
