06-01-2019 19:09
06-01-2019 19:09
New Inspire HR shows a step count much too high. Can this be remedied?
Best Answer06-02-2019 06:15
06-02-2019 06:15
You can try a restart.
Otherwise, that's not enough information to go on.
How much too high are you talking about?
What were you doing during that time?
See How accurate are Fitbit devices?
Best Answer06-02-2019 06:44
06-02-2019 06:44
About 50%; i.e. 3000 instead of 2000. I just switched setting to dominant hand to see if that helps. I am pretty much ambidextrous and use either hand for many things. Any other suggestions? Thanks.
Best Answer06-02-2019 07:03
06-02-2019 07:03
Is that for a day, or for one particular activity? How do you know 2000 is correct instead of 3000?
Find a place you can walk several hundred steps without interruption. Stop for a minute to makes sure display is caught up. Note step count. Count steps, each footfall is one step, as you walk, swinging arms naturally. Stop, wait a minute to make sure display caught up, check step count and compare to what you counted.
That will at least tell you if it is counting correctly when simply walking.
