03-27-2019 12:36
03-27-2019 12:36
Hi all, I just started using my newly purchased Inspire and have a question regarding sleep tracking. I have been using a Fitbit One for a few years and no problems tracking sleep, just had to remember to start and stop the timer.
Now to my question. I am using the Inspire in the clip mode. Will the Inspire track sleep with the device clipped to my tee shirt while sleeping or do I have to have it on my wrist? With the One I was able to track sleep while the device was attached to my tee shirt.
If this is not the case then at best I will have to re-attach the wrist bands and change it from the clip mode every night.
Sorry for the length of this question.
Looking forward to your replies.
Thank you!
03-27-2019 13:50
03-27-2019 13:50
Hi, @hdflhtcu , you will need to set your Inspire to "wrist mode" for it to track sleep, and you should not use the app to start sleep. As long as it is in wrist mode it should track your sleep automatically.
You will need to experiment to see whether you can still get reasonably accurate details if you wear it clipped to your body (but in wrist mode). It is definitely designed to be worn on the wrist in sleep mode. If you do not want to add the wrist bands you could also slip it into the One sleep band if you still have that
03-27-2019 13:50
03-27-2019 13:50
03-27-2019 18:48
03-27-2019 18:48
Thank you, I will try and keep you posted.
03-29-2019 12:00
03-29-2019 12:00
Hi again, I tried your suggestions and it seems to have worked. I set it to wrist mode in the evening and back to clip in the morning and somehow it is now tracking my sleep. Just FYI I slipped it into a pocket and it still tracked my sleep. Go figure. Thanks again for your help!
Best Answer04-03-2019 11:30
04-03-2019 11:30
these frigging watches that does not come with any kind of instructions. What is this making the watch wristmode? I slept with my HR last nite and I know fell asleep around 8pm or 2000 hrs. Logged into my webpage and it says I went to sleep at 2300 which is 11PM. I woope at 0230 and it said I slept till 0405. WRONG I tried to change the from and to but it kept erroring. Why am I waiting $100 on a piece of crap that you need to be a genius to operate? I am not very puter or electronics knowledgeable. Alml I want to do is track how far I walk my dog twice a day and how much sleep i get. Already found out HR does not track deep sleep and/or light sleep either so this HR is a piece of **ahem**!!!
05-01-2019 17:34
05-01-2019 17:34
I just got my Inspire today, NO INSTRUCTIONS OR MANUAL
Ticked off
05-01-2019 17:39
05-01-2019 17:39
Wow, have had my ONE forever, never knew it tracked sleep in the clip, i had a wristband I put it in for at night.
Hope I enjoy this Inspire as much as my ONE!🙂
Best Answer05-02-2019 08:03
05-02-2019 08:03
Best Answer05-06-2019 07:42
05-06-2019 07:42
Since no instructions came with the **ahem** watch what the heck is wrist mode? And how the hell do you it? What is this APP thing you said to not use to start sleep? I go to the fitbit web page on my desktop computer to see the info. I have no APP.
05-06-2019 10:16
05-06-2019 10:51
05-06-2019 10:51
Best Answer05-06-2019 10:52 - edited 05-06-2019 12:27
Best Answer05-07-2019 09:35
05-07-2019 09:35
Not sure why this thread is marked as “solved “ when ,despite all attempts to fix/adjust settings and use, the sleep tracker is not accurate!
06-23-2019 08:46
06-23-2019 08:46
Having same problem as everyone else sleep doesn’t work no manual no help
11-03-2019 10:44
11-03-2019 10:44
How the heel are you supposed to set it to "wrist mode"? Taint no friggin instruction on how to do all this **ahem**!!! I am not the best at figuring out all the ins and outs of these friggin contraptions!!
Best Answer11-25-2019 13:50
11-25-2019 13:50
Hold button down until menu slides over. Scroll down and tap screen to change setting from On Band to On Clip
Best Answer02-01-2020 12:50
02-01-2020 12:50
You can access wrist mode by holding the button and scrolling to the bottom.
Best Answer02-01-2020 14:40
02-01-2020 14:40
Holding what button?????
Best Answer02-18-2020 01:16
02-18-2020 01:16
The button the left side of the inspire
