07-24-2019
07:22
16:35
AndreaFitbit
07-24-2019
07:22
16:35
AndreaFitbit
Black screen after charging . Tried reset while on charger. No smiley face , no anything . Vibrates.
Have had less than a year .
Very upset
Moderator edit: updated subject for clarity and format.
07-25-2019 06:54
07-25-2019 06:54
Welcome to the Fitbit Community @DJHarts and @tcohn! It's nice to see new faces in here. I'll be glad to assist you with your Inspire screen inquiry.
@DJHarts, thank you for trying a reset. I went ahead and created a case on your behalf. Please check your email and let me know if you need further assistance.
@tcohn, confirm that your device is charging properly and restart your device (you'll find the instructions on attached help article).
@NellyG, thank you for the heads up.
Keep on visiting the forums.
07-24-2019 11:18
07-24-2019 11:18
ving the same problem with my new inspire. Had it less than 2 months. Can not get the clock, steps or anything on the screen. Just a battery and light bulb.
07-25-2019 01:29
07-25-2019 01:29
I have flagged a moderator to come and help
Helen | Western Australia
07-25-2019 06:54
07-25-2019 06:54
08-01-2019 18:32
08-01-2019 18:32
It is charged and it does track on the app, but it is still a blank screen on my inspire . So it did not fix the problem . Thank you for responding
10-20-2019 08:54
10-20-2019 08:54
Did you get an answer? I’m having the same problem as yours. I already sent an email, tried the suggestion they gave you, bought a new charger to see if that was the problem and nothing! I need help!
10-24-2019 01:27
10-24-2019 01:27
I had the same Black screen another community user suggested that we change the screen display on the fitbit phone app. I did this and it worked so thank you to that member. Sorry I cant find the thread anymore but I recommend this tip.
11-08-2019 06:27
11-08-2019 06:27
This just worked for me! I switched the clock screen and it came on.
11-08-2019 06:58
11-08-2019 06:58
It's great when you get a resolution ! So glad it helped
12-06-2019 06:38
12-06-2019 06:38
My Inspire screen when black today. I think it was black when I took it off the charger this morning (I generally slap it on my wrist without even looking at it). I tried to reboot and it only vibrated. The thing is it's still active because it's recording steps per my phone app. What to do? Any suggestions? Thanks.
12-06-2019 11:10
12-06-2019 11:10
12-13-2019 21:02
12-13-2019 21:02
My screen is also black. Starting to research this issue and from all the hits, I can see it is definitely a known problem with the Fitbit inspire. I haven’t found any solution posted besides replacement. Will the moderator please reach out and let me know how to remedy this? Thanks
12-21-2019 09:51
12-21-2019 09:51
Go to your account settings and change the clock face to another option. You can then set it back to what you want but for some reason this works. I have had this work twice for me. Good luck.
12-21-2019 09:53
12-21-2019 09:53
12-21-2019 23:17
12-21-2019 23:17
01-05-2020 04:02
01-05-2020 04:02
Hi. I'm having the same issue.. Was able to reset once and it worked but black screen again after 2 days. Changing clock face also did not work. Is working through the app only.
Only given as gift in Nov 2019. Very disappointed!!
01-07-2020 06:22
01-07-2020 06:22
01-16-2020 14:12
01-16-2020 14:12
I’m also having the Inspire blank screen problem. Tried the reset suggestion. Also tried change the clock face. Nothing’s working. It is syncing to the app, however. Help, please!
01-16-2020 21:41
01-16-2020 21:41
Hi. Fitbit replaced mine for me. Contacted customer service and no drama at all to replace.
01-17-2020 02:44
01-17-2020 02:44
