08-31-2020 15:07
08-31-2020 15:07
My screen is blank. The vibration is working but when I tap the screen or press the button nothing lights up. This has happened a few times but usually resolves itself but this time is lasting a lot longer.
Best Answer08-31-2020 15:17
08-31-2020 15:17
This happened to me after I did the firmware update. Reach out to customer service and they may be able to help. If you are within your one year warranty, they could replace it. I'm outside of my warranty so they won't send me a new one. You can try restarting it and changing clock faces. That was the only advice I was given before they said there's no way to fix it.
Best Answer09-01-2020 01:53
09-01-2020 01:53
Best Answer09-01-2020 03:36
09-01-2020 03:36
I bought a new inspirehr just over a week ago. I could not get it working so I contacted customer care. They decided to send me a replacement---reconditioned apparently. And I am having the same problem.
I tap/push the button and tap/swipe the screen and nothing happens.
Maybe I have not set it up properly!!
