07-03-2019
16:39
08:25
AlvaroFitbit
07-03-2019
16:39
08:25
AlvaroFitbit
my inspire unit is missing steps. for some reason it does not count all my steps. any suggestions?
Moderator edit: format
@DebraSB Welcome! It's good that the community is growing!
Let me help you with your step count. Your device will detect the movement on your arm and translate that movement into steps. There are situations in which your arm may be still but you could be moving or walking. This may happen when you are pushing a cart or holding bars while walking or doing treadmill. For added sensitivity you can try wearing your device on your dominant hand but select that hand as non dominant on the device’s settings to make it more sensitive to movement. Also make sure your hands are moving so the device can properly track your steps.
Let me know how it goes.
Best AnswerMy step count is now very undercounted since the update and I am not moving any differently than before.
