10-19-2019
11:55
10:15
AlvaroFitbit
10-19-2019
11:55
10:15
AlvaroFitbit
Hi,hello to all. My question is, as the title says, my fitbit has not registered anything since last sunday. It is charged and so is my phone and laptop etc. (bluetooth on, iv not changed any settings at all )Any ideas?
10-20-2019
10:16
06:01
10-20-2019
10:16
06:01
@SunsetRunner Welcome to the Fitbit Community! It's great to have you here!
Let me help you with your Inspire not syncing. Which phone are you using? Is it compatible? You can try the following:
Let me know how it goes.
Best Answer10-20-2019 10:53
10-20-2019 10:53
Have you just installed the Firmware update by any chance?
If so, I had the same problem but this worked for me: https://community.fitbit.com/t5/Inspire-Inspire-HR/No-longer-automatically-tracks-exercise-or-sleep/...
I seem to have to manually sync my Fitbit now 'cos it doesn't seem to want to do it automatically any more, but I hope the thread up there ^^ works for you!
Best Answer10-27-2019 01:38
10-27-2019 01:38
Many thanks for your reply. Im sorry for the delay in answering (laptop broke!)
All seems to be working fine now, no idea what happened before but it seems fine now.
Thankyou
Best Answer10-30-2019 10:24
10-30-2019 10:24
same is happening to mine (kinda)
Best Answer10-30-2019 10:53
10-30-2019 10:53
I so hope you get it sorted.
Mine was a signal issue, and this made it not possible to sync (i think!),
So now i make sure there are time when both phone and fitbit are both in full signal,so they sync.
Not had any problems since doing this. x
