09-30-2019
06:47
11:51
AlejandraFitbit
09-30-2019
06:47
11:51
AlejandraFitbit
I received my new Fitbit today, have registered it an created account, however the Fitbit screen just shows the icon and scrolling www.fitbit.com/setup. It syncs with my phone but cannot get the device to even show at least the clock, please help 😞
09-30-2019 14:01 - edited 09-30-2019 14:04
Hi @SunsetRunner,
The good news is you've saved yourself some time by creating a Fitbit account. Download the Fitbit app on your device (I assume you're using a phone, but you could use a computer or tablet) and log in.
Once you log in, you should see a tiny version of your Fitbit icon in the upper left corner. Turn your Bluetooth on and tap the Fitbit icon.
Go into your Bluetooth settings and connect your device to the Bluetooth, you will need this in a later step.
Go back into the Fitbit app and select "Set Up New Device". From there, select "Inspire/Inspire HR" and follow the prompts.
As a side note, all other Bluetooths should be either turned off or moved during this process so the tracker doesn't get confused.
one cruise ship at a time!
11:51
07:41
10-03-2019
11:51
07:41
Welcome to the Forums, @SunsetRunner and @DramaQueenDiva, thanks for the input.
I was able to see here that our friend @DramaQueenDiva provided some instructions in order to fix this setup issue. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out. 🙂
Best Answer04-24-2020 15:25
04-24-2020 15:25
My issue was other Bluetooth device at home (exactly the Philips Hue Plug). I have turned off all other devices and finally I was able to finish the setup.
Best Answer07-08-2020 10:30
07-08-2020 10:30
I am trying to setup the inspire, but on the screen that asks to select the type of device, inspire is not listed. I just bought it, is it already discontinued?
Best Answer08-14-2020 14:17
08-14-2020 14:17
My Fitbit Inspire HR had been fine but then the time/clock all of a sudden was wrong and it wouldn’t sync with the app on my iPhone 8. I did a soft and then a hard reset, but when I try to setup the device again, it finds the device but then gets to the “connecting to the tracker” part and stays there for literally hours. My phone’s Bluetooth won’t connect to it, either. Is this fixable or do I need to send it for warranty work/repairs?
Best Answer08-14-2020 14:41
08-14-2020 14:41
Got it! What finally allowed the device to connect was going into the Bluetooth settings on my phone and removing all other Bluetooth devices by hitting “forget this device,” even though they weren’t nearby or connected. I hope this helps someone else! It was very frustrating right up until it was fixed.
Best Answer08-20-2020 18:02
08-20-2020 18:02
I'm having the same exact problem. Did you ever figure it out? The Inspire isn't even listed in the tracker setup options
Best Answer08-20-2020 20:29
08-20-2020 20:29
